weird screen isseu after screen replacement
Dear,
I repair for living , so i have an Hp slate 7 here for screen replacement.
i only replaced the digitizer not the full assembly.
Now i got this weird $@$* problem with the screen, probably this is weird for you all...
So i did the repair perfectly i power on the tablet no problem...
trying some things to test the new screen again no problem..
Tablet goes in 'standby' i power it on again and now touch screen wont do annything.
So checked the cable removed it and re-installed it , i power tablet on test touch screen... no problems
tab goes in standby and then touch wont work...
anny1 had this problem before? maybe with other tablet/phone?
UPDATE: Reconnecting the batterie makes touch screen work again till it goes in standby.
Hi,
Does it work OK with the charger connected and on? If so, look at the battery, it may be failing under load.
