Diy pressure washer to a misting pump?
Hi, how to make a pressure washer deliver water out without pulling the trigger gun?
Please help. Thanks
Please help. Thanks
You can't , it's a pump and doesn't work without pulling trigger. Why would you want to do that anyway ? Use a regular hose
I want to use the pressure washer pump as a misting pump.
Well you can just not start the pressure washer and just have the water pressure push the water thru the pump and then you can pull the trigger and walla , mister of course the right nozzle makes the difference
Azizan did the pressure washer work for your system?
The Trigger doesn't turn on the power washer it just allows the water to flow out the wand. Once the pressure drops the power washer turns Cycles back on. It you hook a power washer up to a mist system the pressure will pull the water through the system. What need to be modified is the cycle valve needs to be changed into a regulator valve so that the water pressure consistency is constant.
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 2,496
