Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
No signal after lightning port repair attempt
I replaced the lightning port/headphone jack in my iPhone 5s and have discovered two problems:
1) the lightning port now recognized the lightning cable like a champ (indicates connection, displays lightning icon next to battery icon; had tons of trouble before), but the battery does not actually charge
2) I have the dreaded "Searching" at the top left of the display. WiFi works, but no other signal
In researching this site, I found the suggestion to check the IMEI and ICCID numbers in Settings. Both are missing. This sounds bad and I read elsewhere that this would appear to be a death sentence for the device, but I wanted to check and see if it would be at all possible that I just got a bad/cheap replacement part. I bought this one for very cheap on Amazon. The replacement process went fine, with nothing appearing damaged/broken and all cables reassembled correctly.
I'm hoping there's a chance that buying a higher quality part will do the trick, but need some expert feedback. Hopefully Tom Chai can chime in, as he seems to be a genius. Other geniuses welcome too.
Third party parts will usually give you third party problems
Try this
iPhone 5s Lightning Connector and Headphone Jack
Use this, just in case
iPhone 5s Lightning Connector Replacement
crwdns2886500:0Replace a lightning connector or headphone jack compatible with iPhone 5s. Includes cellular antenna and microphone to save time during the repair. Models A1453, A1457, A1518, A1528, A1530, A1533. Part #821-1596-A and Part #821-1667.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$24.99
Thanks for the reply. Would you say that a 3rd party lightning port could be the cause of the "Searching" and IMEI/ICCID issues?
It could be. I'm inclined to believe so, because you said you have other problems with this lightning dock. I have no idea why you can't find your iemi in settings. You should also try resetting your settings
all iphone parts will be third party including ifixit
I reset my settings and nothing changed. Still "Searching" and still missing the IMEI and ICCID.
Good to know that ifixit doesn't sell OEM parts. Don't really want to spend $30 for nothing but may give it a shot given the alternative.
ifixit sells high quality parts. That why I suggested it. You pay more for better quality parts
I've heard of heating the Baseband chip for 4-5min at 400f and it fixing it. but first try backing up and restoring. if it throws error -1 then try reflowing the chip.
Im not 100% sure about the battery issue you are having, but check the time on your phone. I always unclip the battery when I do screen repairs and I had the searching issue on an iPhone 5s. I checked the time and it was set to 1977.
The date/time is correct on the phone. I didn't remove the battery for the repair.
You can usually fix that by connecting to wifi
I was connected to wifi. Nothing I tried would fix it other than manually setting the date and then selecting automatically set time. This was the first time I've seen this happen.
tahota49 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,092
