Repair and troubleshooting information for the Suzuki FA50 Moped.
Refurbishing an 30 yr old bike
I was given a suzuki shuttle scooter 1982 model. It has been sitting for 30 yrs untouched. When it was parked it ran fine. I am wanting to get it on the road again. What would be the first things to check ?
Drain the oil and gas first. Before doing any attempts at starting it remove the plug and put some diesel fuel in the cylinder to soften up any scale or rust that may be on the cylinder walls. Let it soak for a day or two . put some new oil in the bottom end then try to turn over the motor. dont want it to start yet just want to make sure you can move the piston . next clean out the carb . if you can get a carb kit now would be a good time to do it as the gaskets will be toast . clean the magneto and see if you can generate a spark. Once you have a good spark (replace the plug maybe even the plug wire). crank the diesel out of the cylinder till it seems dry.load up with fresh gas and try to start it. run it for a short while 10 to 20 minutes and change the oil again . then you should be good to go . Hope this helps and have fun
What plug you mean like the spark plug?
I'm referring to the spark plug
I would take the seat off ,then pull out the fuel and oil tanks.these tubular frames are notorious for attracting mice who usually chew the wiring harness.
Also look on line for a forum for your bike. Often those user forums exist and many enthusists will be keen to help you get her rolling again. The advice above is very good as well. All that is needed to get rid of bad gas and gunk in the carbs, as well as oil gone to lumps.
angelacrawford25 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 927
