Released in North America in November 2006, the Wii was Nintendo's first home console to directly support Internet connectivity, supporting both online games and digital distribution of games and media applications through the Wii Shop Channel.
Teardown/troubleshoot for balance board?
Are you planning a similar troubleshooting and teardown guide for the balance board?
I've found that after a while they start losing connection to the console, particularly when stepping or other more-energetic activities.
== This is ==
a DIY help forum (guides are created by volunteers - you could make one) - check back for new guides.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Sorry, I could only get you these. The board bottom has basic phillips drive screws but the sensors themselves have large Torx screws I don't have a driver for. But here is the opened underside.
Personally I've noticed some of the software (games) for the Wii will sometimes lose sensitivity after a period of time playing, similar to an un-homed stepper motor over time losing steps. But if this isn't that sort of problem check the the cable connector between the battery compartment and the main board; the cable connector can be pulled out/put in pretty easily. The compartment only has two screws but can only be pulled up after the main underside comes up. Feet come off first. Hope this helps :)
P.S. There are no hidden screws or out-of-the-ordinary bit drivers needed to open it up
Walter Morris crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 4,486
