Why is there a loud squealing noise from the left speaker
But when I hold the mute button down it stops and then when I turn them off it goes away
I found a solution that works for me, turn of noise cancelling. To do this (If you have studio 3’s (mine) or solo’s) double click the button on the bottom right side of the head-set. The sound goes away for me
Thank you so much man
That works for me too... needless to say, that buying „active noise cancellation“ to then having to turn it off is just sad ...
And did you also observe, that the white noise is on one side (left in my case) only?
thank you!!!!!!
Worked on my first gen Studios! Contacted support a couple of years ago when the issue first arose and they didn't have a clue. Was gonna junk these and ended up partially recovering due to this advice. When I turn on ANC only, I get loud white noise. When ANC is on with audio feed, it is an ear shattering screech. Now with ANC off, I'm back to relaxed listening...
thanks for the help!
I've had the same problem with Executives. Beats are junk.
Could be a loose cable or solder point.
Is replace the bad speaker. (Req soldering)
So my main question is do I keep them or junk them ? Part them out possible or is that even a waste of $300 aslo!?!?
If you can solder and are willing to get them to work again, you should keep them and get a new speaker from eBay. If you don't harness the skills, then I would sell them for parts and get it over with. They are old and aren't worth much however.
I have the same problem and I am taking them apart at the moment, my conclusion is that these are how the headphones were designed and is a flaw in beats attempt to make these headphones “noise cancelling”.
My Beats 1s are making a really loud screeching sound and I do not know what to do
ive experimented on this and found the answer kinda. it has something to do when the earbuds are connected or connecting disconnecting etc. the waves connection the earbuds could create high screeching sound like a radio of a car not finding a signal and static shows up. ive tested this and its the most likely cause. ive closed my fist around the earbuds individually and it made the noise. currently there's probably no way to fix it besides the manufacturing doing something about it on how the beats headphone communicates with other devices. The is just a guess and not a final answer i will be testing more when i get to it.
I just figured out if you have the Beats headphones not earphones the really loud sound from the ear when you lay on your side iv because of the noise canceling it makes everything quiet but laying on the headphones will disrupt the communication so if you don’t want this problem you will need to turn off noise canceling
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 60
crwdns2936753:030crwdne2936753:0 225
crwdns2942667:0crwdne2942667:0 17,624
