Replace Power switch G4 Mirrored drive door
The Power switch seems to be held in by two plastic pins. Do I force the center pin on thru the pin or cut the head off the plastic pin.
Push the plastic tabs down to release the unit.
The plastic pin that you remove holds the one beneath it in place. After removing the top one the one beneath it can be removed the same way. The top one spreads the lower one locking it in place.
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 2,347
