An Android smartphone by Samsung for the Asian market, known by many model numbers, released December 2014. Includes models SM-A5000, SM-A5009, SM-A500F, SM-A500F1, SM-A500FQ, SM-A500FU, SM-A500G, SM-A500H, SM-A500HQ, SM-A500K, SM-A500L, SM-A500S, SM-A500YZ, SM-A500Y, SM-A500W.
My phone is not charging
Well i phone will not charge i got a new charger but it still dont charge
crwdns2889612:0crwdne2889612:0 10
my dont either
crwdns2933315:06crwdne2933315:0
How be we check out the charging port first , is there dust dirt or debris of any sort in the port itself . Often lint from your pocket will get into the port and then gt driven in further when you plug in your charger . clean it with IP alcohol and a toothpick (wood) dont root round in it with anything metal.Next is the inner part of the port loose does it move at all this isnt good . If not does the whole port move in the phone . If your comfortable opening your phone you can replace the charger port
http://www.ebay.com/itm/Samsung-Galaxy-A...
they are a plug in unit which is easily replace unlike some that need to be soldered in
heres a teardown video to help
https://www.youtube.com/watch?v=gKX3iHPK...
Thats a problem as the charging port is only accessed throng the screen. Take it to a local repair shop for assessment, a quote should be free.
dust maybe the problem inside port cut small piece of plastic try and remove dust a thin bit of plastic like
I googled this same question, looked everywhere, tried trouble shooting, deleted cached data, tried to charge on safe mode or while off etc.
Then, I just tried to turn off my blue tooth and location finder and finally it started to work!
it might be a software glitch try factory reseting your phone
When I connect my phone with the charger ,it comes this notification ; (check port moisture has detected.To charger your device,make sure your charger / usb port is dry ) and I am sure that my device port and also my charger is full dry .I tried some times to restart it but it's not working
Nick Zunigs crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 40,265
