The Beats Pill is a small, portable Bluetooth speaker from the Beats by Dre line of products produced by Beats Electronics LLC. It features direct audio and Bluetooth connectivity as well as an internal microphone to conduct phone calls. This device is fairly capable of being repaired due to its intuitive construction.
Beats pill will not charge
When plugged in & switched on it will not charge
Hi,
Have you tried unplugging the USB cable out of the power adapter, then connecting the cable into a USB port of a turned on PC? (the speaker is connected to a PC via the USB cable to see if it charges)
If it starts to charge you have a faulty power adapter.
If it doesn't, try a different micro USB to USB cable and see if it charges now.
If it does you have a faulty USB cable. Try the working USB cable with your power adapter to check if the power adapter is OK.
If it still doesn't charge, you either have a faulty charging circuit or a faulty battery in the speaker.
Louise ryans crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 3,543
