Released in December 2011, identified by model number LT2016U. Repair requires screwdrivers and pry tools. Black / 10.1" Display / 1.6 GHz Intel Atom Processor
How do I reboot gateway model kva60
how do i reboot gateway model kva60
This question was migrated from http://meta.ifixit.com/Answers.
reboting simply means to restart a computer you have a cold boot that is when the computer has been idle for hours a warm boot is when it has been running and in that time was restarted. when it first starts up it does what is called a post stands for post operating systems test that checks things to see if it is in order it is done in milleuseconds than you into the operating system.
simply put when your computer is running restarting it means reboot.
If you want a true reboot, you'll want to unplug your LT20 or KAV60 from the power supply. Secondly, remove the battery from the bottom using the two little slide switches near each end of the battery. Once you're done unplugging AC adaptor power, AND you have removed the battery, turn it over and press the start button 3 or 4 times. What you are doing is depleting all residual energy from memory modules and other items inside the computer case. Once you've done this, you may put the battery back in, as well as re-attach the AC adaptor cord to the right hand side of the LT20, or KAV60. Now, you may start the computer knowing you have just done a complete and clean reboot. This is different than just having a program ask you if you want to reboot from perhaps a driver installation, or an update or anything. Those would more than likely be considered warm reboots, but information could still be retained in memory, maybe malware commands, and virus type things. Having a clean reboot prevents that.
Freddy crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 447
