Popular laptop sold by HP. While it comes in many configurations, all models of this laptop have the same basic form factor. The numbers after G60 indicate the factory specifications of the laptop and who sold it.
heat then I see almost 100degrees celsius
by the way im new only
i have laptop g60-249wm and also i cleaned the fan and fan is working correctly and i have already too cooling fan in down on notebook or laptop
and
always get a heat and i install some application that can read about heat then i see almost 100degrees celsius i got i dont know how im adjust the brightness that can more longer heat and it was -8 degrees celsius and now its 92deg......... but it still hot is there anything too make this low ???? im always sad because of this :( feeling bad with hp g60-249wm
i feel you answered this soon :(
Try running the laptop on power saving mode or balanced mode, that helps a lot!
well already do that and now its 80 but is thier anything upto 50degree celsius or less ?
cbpwin, I suggest that you open up your computer and clean the fan, the air inlet slots and replace the thermal paste. To get a better idea about what the normal operating temperature should be, you got to let us know what processor your computer has.
what is thermal paste and how much is it and where i can find it ??
++My Location: PH ++ but you can answer $ i will convert it
and also i clean already the fan but i dont know what is thermal paste so i did not use it and if i got that thermal paste how much heat will lose ?? 10*+ or 10*- ???
computer graphics are nvidia
processor is AMD Athlon Dual-Core QL-62 2.00 Ghz
The maximum operating temperature for the processor is 100deg Celsius. This link tells you what thermal paste is and here you can find out how to apply it.
cbpwin crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 216
