Repair guides and troubleshooting for the 40in LCD TV with model number LA40R81BD or LA40R81BDX. This television was released in early 2007.
Can it accept 220V power?
Do you know if a 110V samsung TV can actually accept 220V power? The power supply says 110-220V on the inside, but on the outside (on the sticker with model name and other info) it says 110V.
Mark the master electrician needs to travel more. Outlets in the Philippines look kust like US 110 outlets but are 220v. Europe isnt the only place with 220.
a1challenged yes it can. Always check a power supply not just for voltage but frequency as well. Yours is a 110/220V and it should be 50/60hZ. Post an image of your power supply with your question to verify. Use this guide to do so
hz is not volts and as i said 220 plugs are different than 110 if you can put a 110 plug in a 220 outlet you are a better man than i and i will eat crow if you can show me how its done ASE Certified Master technician
30 years
mark, I am aware that hz is not volts. Those are hertz nor did I anywhere imply that it does. European house hold voltage is 220V and 50Hz frequency. The power supply in this TV is a dual voltage power supply, it supports 110/220 V and a frequency of 50/60Hz. So, yes you can use it. As for a plug, you are correct it will not fit any outlet if it is North American style. This is not to say that you cannot use either a plug adapter or install a different power cord. If you read the question, it does not ask if the plug fits, but if the power supply can accept 220V. "ASE Certified Master technician 30 years" congratulations on that, great career choice.
you are correct in what you say it seems as i made a ASSumption i probably should not have being that we are in north america can you imagine a tv with a 220 plug on it on our side of the pond [lol] so technically you are absolutely correct but as a matter of practicality well enough said my hat is off to you sir
mark, it's all good. Really no big deal for as long as we think global on here:-)
as it should be just hate to be wrong you know peace out.
a1challenged crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 8,411
