An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
crwdns2934591:0140crwdne2934591:0 crwdns2934593:0crwdne2934593:0
My Starbucks lights are on but nothing is happening
My Starbucks doesn't show any sign of life. The light is green for water ready. Nothing happens you press the button for making coffee . I can't even here the water boiling. Can you help me out please.
Hi,
If you can read a wiring diagram, this answer provide by OldTurkey03 will probably be of help
Is there a wiring diagram? (click on the wiring diagram to enlarge)
Here is the Ifixit link for Starbucks Barista Repair.
Starbucks Barista
If neither pushing the coffee button or opening the steam knob cause the pump to turn on then you either have an electrical fault or your pump has died. If you have a multimeter it's fairly simple to check to see if the pump is getting voltage or not, but a failed pump is a much more likely culprit.
Gordon White crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 141
