Why is my device constantly power cycling?
The device will charge fully and drain to 50% than die almost instantly...
Most likely this is an issue with the connection of the battery. Try disconnecting the battery internally and then reconnecting it.
how do I open my tablet
@cabrich1957 Assuming we're still talking about a The Trio Stealth-10 tablet, there's a battery replacement guide available here on iFixit.
Trio Stealth-10 Battery Replacement - iFixit Repair Guide
Unfortunately, Ian Russell's solution isn't a great one, as the battery doesn't use a connector that can be unplugged; instead the battery is soldered directly to the motherboard. So you'd need to use a soldering iron to disconnect the battery and reconnect it.
If you're experiencing the same issue as the original poster, I would disagree; this sounds very much like a battery that has reached the end of its useful life and needs to be replaced. That would be the first thing I'd try in order to fix the issue.
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 321
