The router wont power on
My Netgear router WGR614 won't power on, it was working fine earlier. I moved it to a new apartment and now it won't work. I've tried unplugging it and plugging it back in and still nothing.
try the rest button small pinsized hole in near ports
Thank you so much I’m retarded thanks lmao
Sounds like a power supply problem.
1: Replace the power adapter with one equivalent to the original to eliminate a bad adapter.
2: Open the adapter to see if you have swollen capacitors (cap) , if so replace it or them.
3: Open the router carefully and make sure you don't have swollen caps. If so, replace them. You can tell a swollen or bad cap by looking at the top of them. It should be flat. If the tops are round or bubbled , place them. Also look for burnt or deformed components and place them .
Let me know if that helps to narrow down the problem . And let me know if the problem still exists .
crwdns2942667:0crwdne2942667:0 14,236
