Lenovo IdeaPad, Yoga Series. Released October 2013, 13.3 inch screen, 8 GB RAM, 2 GHz CPU, 512 GB SSD.
crwdns2934591:015crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Why is my Lenovo Yoga 2 Pro not connecting to Wi-Fi?
My Yoga 2 Pro won't connect to Wi-Fi and I can't get on the internet at all. I've tried restarting the device, as well as turning off Wi-Fi and turning it back on again. How can I fix this?
crwdns2944067:06crwdne2944067:0
just update the wireless adapter and get fixed it with lenovo https://goo.gl/z48Cpy and see if this helps you
Actually I have a way that works for me.I think the wifi issues are due to static on the wifi adaptor.
Solution is to start the pc and then shutdown.Wait about 10 secs and then restart.Wifi will work again.Do it for all restarts .
taraysingh...awesome fix! ty
taraysingh-thanks it worked
Just tried - it works! Thank you so much!
Greetings Riley,
You should first try to update your Wi-Fi drivers from the Lenovo downloads page.
http://support.lenovo.com/us/en/products...
Happy Fixing!
crwdns2942205:01crwdne2942205:0:
If wifi doesn't work
HTF can I download updates from lenovo's website
just update the latest wireless adapter in you laptop and check the firewall settings and make sure its not blocking it . if does not work than go to wireless driver reset it and restart the computer and if nothing works visit http://support.lenovo.com/in/en/GlobalPr... and lets see if this will help you
Wow what an awful response. I click the link and it says nothing found. Also, the problem is that I can't connect to wifi. Thanks for sending a link that requires wifi. You're great.
This response is from last year; the link may have been changed by Lenovo. Currently, the drivers are available here. You can download them using another PC and then transfer them to your Yoga 2 Pro using a USB stick. (Or simply plug in to ethernet, if that still works.) I understand why you are frustrated, but try to remember that members of this forum are volunteering their time to help out; you're more likely to get help without the attitude and sarcasm.
  1. Try reboot.
  2. Check driver.
  3. Update your laptop.
  4. Factory reset your laptop.
How to fix lenovo wifi problem
You can refer this article too this will help you in solving your problem.
Riley Ormiston crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 50,884
