Darts fall out of gunbarrel
The dart is loaded in the gunbarrel, then the three pins at the bottom of the barrel pushes it 2-3 cm out again, thus the gun won't fire effectively.
Any good solutions? Thank you:-)
I fixed it! super easy! I have a firestrike and a sharpfire I think 3 darts is not enough so I grabbed some from my sharpfire. they worked for a while but then it stopped working. I was all sad be couse I thought it broke, when I looked closer at the darts I noticed 3 of them had a W and the others had a Y! aperently the elite darts have more groups! the w's are for the firestrike! I hope it helped, sorry if this didnt help.
have a good day!
What is happening is that the darts are getting worn out and are not gripping the barrel enough, I would suggest picking up some cheap knock-off darts and testing it.
This is a common problem with front loading pistols. You have to buy new darts because this happens with worn darts
Here this kid had a perfect answer.. it worked 4 my sons gun.. widening the inside diameter of the round with a pencil or part of tbe gun.. https://m.youtube.com/watch?v=247shtsb0z...
I got my nerf guns down from the cupboard after years of non use and had this problem. The pencil works a treat!!! TOP TIP
Awsome.........
The same was happening to my big shock blaster and I found that squashing the darts for 4 seconds will solve this issue.
If it isn't working, try squish harder, I did it so the dart was basically flat.
EDIT:
PS: the darts will drop a bit more, so if you are using this in an actual war, make sure you aim up a bit more. NOTE: they won't drop too much, so don't worry.
It worked for me, but i dont think it will be a good idea if you have other guns you want to use your darts for.
I took a small section of Scotch tape and wrapped it around the rear end of the Elite darts to give them a bit of extra girth. That did the trick. You may wish to try other types of tape, but you get the idea.
Try opening up your firestrike and there should be a big white tube at the top beside it should be the air restrictor and it should have 3 pins and a spring behind it. Take out the spring and the 3 pins and your good.
and put the shell back on and everything
Don't do this unless you're doing a spring upgrade and need to get every last bit of performance, because this will make your blaster break faster by firing it, especially without a dart in the barrel. Most modern blasters don't need their air restrictor removed.
remoove the dart post using plyers
When it happened to me, I simply tried pushing it in further (but not so it gets stuck). Make sure to be careful as when it got stuck, I had to use tweezers and it ripped the plastic off the top. I had to buy new ones but I also agree with Jay s as usually they're just worn out so my method will work but after a while the bullet will get so misformed it won't work and the bullet will be a piece of junk taking up space.
Simple. The darts are worn out. Purchase some off-brands like Waffles or Accufakes prolly on Amazon
crwdns2936753:030crwdne2936753:0 59
crwdns2942667:0crwdne2942667:0 26,995
I have the same problem. I'm about to open it up and see what's what but im 16 and not an engineer...good luck to me though!
crwdns2934271:0crwdnd2934271:0 tpfootball45 crwdne2934271:0
lololololooolololololololololollololololololololololololololololololollolololololololo
crwdns2934271:0crwdnd2934271:0 azomdos crwdne2934271:0
lolololoololololololololololololololololololo
