The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
How do I upgrade my RAM?
I am looking to put some better RAM into my laptop. How would I go about doing this?
To upgrade your RAM you will need to remove your current RAM and insert your new one. The link attached shows you how to access your RAM through the back of your laptop. Asus X555LA-SI305041 RAM Replacement
Ram is 1.35v or 1.5v ?
Hi @none1986,
According to both Crucial and Kingston RAM advisor system for Asus X555LA it is 1.35V.
how many slots for RAM have this laptop ?
Laptop has only 1 slot for ram. And one is inbuilt
Hey, to UPGRADE the RAM you just add or replace the RAM in the side slot in your guide, however if you need to REPLACE the RAM, one is built in and soldered so that one cannot be replace by the end-user. The one in the expansion bay though, can be.
Alex Turner crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 14,616
