Why is my battery not charging?
On the camera a red blinking sign of a low battery continues to show after having the battery charged over night.
If your battery is not being charged you might need to replace the battery.
As Santos said, you may want to consider replacing the battery. If a new battery does not solve the problem, it may be an issue with the charging cable or AC adaptor for the device or perhaps a loose cable inside the device.
before you go out and spend money on a new battery, just try to reset it. hopefully that will fix your problem.
How do u reset the battery on sony carl zeiss handycam dcr-dvd92e
good question, did u find out?
Id like to know too?
crwdns2942667:0crwdne2942667:0 2,960
