Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Screen cracks without dropping phone.
Need help! I did a screen repair for a customer about 2 weeks ago and today she says it cracked w/out even dropping it. What can be the cause of this? My guess is frame damage? To much pressure against the screen.
crwdns2944067:05crwdne2944067:0
Same here on my iPhone 6s Plus without dropped. Exactly the same spot. The crack emanates from the rectangular handset speaker next to the front camera. It broke by itself under screen glad.
My IPhone 7plus front screen cracked from the top with the crack that emanates from the rectangular handset speaker next to the front camera. This also happened while in a protective case charging on the wall beside the bed . There was just enough room between the wall and the bed for my phone but nothing else. There was no pressure against the screen at all nor anything near it.
No , it doesn’t crack, try to put a very protector case answer put in protect place around your house or school
This happened to me as well and it was not dropped and was in a protected place, where nothing could even get to it, and inside a lifeproof case but it was charging. I am thinking maybe a power surge or something with the battery.
watching youtube then bam i hear a crack boom cracked phone like wtf apple
crwdns2933315:017crwdne2933315:0
This is always a hard call, had the same situation, this summer on iPhone 6. I aggree I would check that area for signs it was dropped. If your not sure I would tell the customer you will replace the screen at your cost this one time.
I know it sucks but some times it's not worth the fight. In my situation gave the customer two opitions I would refund him $60 from the first repair or I would replace the screen at cost for $70 (screens were cheaper then) and customer paid the $70. Three months late I fixed an iPad for that same customer, but you have to be careful because you don't want to be working for free.
Add me to the list. I last checked my phone, went upstairs to work, placed the phone on the desk. Next time I looked at it, it was cracked. And no, I didn’t drop my phone and it has been in a case since day one. I don’t put it in the backpocket, etc.
I have to admit, if someone showed me, I would think there was an impact or something. Except now that it happened to me, it is possible for self cracking, even with a gently cared for phone.
This happened to my iphone 8! Same spot. My phone is in an Otterbox Defender. Did you ever figure out what it was?
This just happened to my iPhone XR , my screen cracked, and I watched the crack run across my screen.
I just woke up this morning and I had a big crack down my screen. I put it charging last night, in a safe position where nothing could fall on it or it could fall and I wake up to find the screen cracked and my phone has an otter box case. I’m really annoyed because I replaced the screen around 2 weeks ago and now it’s cracked even though I didn’t drop it this time,! Someone help please!
Screen cracking on their own, may have been due to bad battery, which expands when going bad. Had this happen.
It is possible. I just found this link through Google because I was searching why my phone just cracked by itself.
my phone broke in my hand during a lighting storm and I don’t know what happened my screen is shattered but I can still see and use the screen.
I placed my Samsung note 10 on the book, after 5 minutes i heard a sound and i looked at my phone and found a small crack on the glass.
After 2 hours the phone was on the table and i heard another cracking sound and i found another crack from the corner to bottom…
no one believes me that it happened on its own…
I was just scrolling through Pinterest. My phone was not charging, my phone was not warm. In fact it was the first time I actually used it today. Then, pop. The screen is cracked straight across… what the heck… I was staring straight at it when it cracked
Most customers will say it wasn't dropped but it could have taken a impact of some kind that will cause the screen to crack. You should take a look at the screen to see the area of impact and make a determination.
I would have thought that too but it happened to my iPhone 7plus as well and I didn’t drop the phone. The screen was cracked after just leaving it charged over night in a secure place. Absolutely no explanation for the cracks on the front of the screen that was in an otter box case.
I've dropped my phone SO MANY TIMES and I mean 2 to 10 or more times a day! Sometimes onto hard floor, sometimes onto fluffy carpet or a pillow or mattress.
2 hours ago I plugged my phone up ON MY BED where I essentially sleep beside it... when I woke up 15 minutes ago and turned my phone back on it was shattered. I have taken dripped it today except for once and it was FINE at the time. Btw i dropped it on to a relatively soft floor (floating hardwood) when I dropped it this morning at 11am. It's now 1 56 am so I guess its technically the next day...
J8st saying... IT APPARENTLY DOES HAPPEN!
@eathomas54 GHOST
just kidding!!! Lol me too though! No reason just cracked phone. Dripped it THOUSANDS of times BEFORE... but not recently. and not hard enough to shatter it
The only conclusion I can come up with was that it overheated and cracked, while charging. My iPhone 8plus was also charging when it cracked inside a protected case with absolutely nothing that could get to it in order to crack it
Are you sure the part was an OEM screen?
I would have not believed a screen could break without dropping it either but it happened to me too. I put the phone on the charger overnight on the floor beside the plug in between the bed and the wall. The phone was the only thing on the floor where it could not even be reached except by your hand as nothing else could fit there. Yet, somehow when I retrieved it this morning, the screen was cracked inside an otter box case.
This same thing happened to me! I had my phone in a case and plugged in charging, where it was out of the way of anything. It was in the same position and when I took it off the charge, it was cracked from the front facing cameras down to the face of the phone inside the case. This is a very gently used phone that has never happened with any other phone ever before.
I think it might be because of the type of charger that made the screen crack but like who knows cause my phone was also charging when it randomly cracked cause I didn’t drop it or anything so
Happened to me with my iPhone 6. I used it before going to bed (no crack). I charged overnight and when I woke up it was cracked. I am not upset however as I am buying an 11 for myself for Christmas :) iPhone is a great product, I mean what electronic device can you use endlessly day after day for 6 years, traveling around the world, and not a single problem? It’s a work horse.
I think is because you drop it in the night and someone pick it up. In the morning you sa cracked
Cracking on their own may have been due to a bad battery or It is possible if the LCD glass to have a flaw or slight crack and heat/cold or vibration can cause it to crack fully much like a car windscreen!
I literally just had this happen to me minutes ago. iPhone5. I was at my computer. I was cleaning battery acid out of a devices internals nearby. Phone was on the charger, plugged into the wall, & on. Not hot, moderately cool to the touch, not super cold or super hot. It didn't move at all, I just heard a crack, looked over, & noticed my phone had cracked. Seeing how many people here had this happen while the phone was plugged in & in a case makes me think that somehow this is maybe a power surge? Not sure if that would do this, but it's a theory.
brianguillen crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 91
crwdns2942667:0crwdne2942667:0 49,346
