Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
Can I use an iPhone 6 battery
i have a water damaged 6s, and i need to replace the batery, does anyone know if i can use an iphone 6 battery, or where i can get a 6s one?
crwdns2889612:0crwdne2889612:0 14
crwdns2933315:08crwdne2933315:0
No, they're not interchangeable, their flex ribbon connectors are different.
iPhone 6S battery: http://www.etradesupply.com/apple-iphone...
iPhone 6 battery: http://www.etradesupply.com/apple-iphone...
crwdns2889612:0crwdne2889612:0 10
Better not. It's not safe. Besides, their size and the internal structure are not the same.
Sizes are nearly identical but the connectors are slightly different from what I see, you can try it for that extra 100 mAh but its better safe then sorry.
I already tried them, they never plug in when it comes to 6 / 6s connector mixing. I do this mistake plenty of times when charging a lot of iPhone batteries on fixtures.
Hi, i already replaced my old iphone6 battery but still don’t get normal peak performance. It says your battery’s health is significantly degraded but my maximum capacity is 100%
hello, first ofall, it matters where the battery comes from, I bought mine on ebay from a seller claiming this was a used iphone battery pulled from an iphone. I’m not sure it’s true, but the battery gradually started working very well, it lasts 1,5days with bad network coverage. After installing new battery, for it to take the whole capacity, you need to discharge it to ZERO, and then recharge it for 12 hours. repeat the procedure 3-4 times. Second, it’s always good idea to hard-reset your phone from the scratch (don”t forget to back up). I set up mine as a new phone whenever I have glitches. Third, VERY CAREFULLY install apps while monitoring their behavior. there are battery managing apps in appstore that allow trickle charging of the battery. this helps putting more energy into the battery. lasts a bit longer too. Fourth, use ORIGINAL charger and reliable cable (I use amazon basics 6foot cable) the parametersof chargers differ from one to another. Then, never buy a woul-be extended capacity batteries with unbelievable figures like “3000MAbattery for iphone 6”. bigger capacity assumes bigger size. The only one thing will work if batteries are interchangeable like in my case : after a lot of research I installed iph7 battery on my iph6s, same desing, same connectors. but I don’t know a similar replacement for iph6. Hope some of these helps. good luck.
Thankyou for the answer have a great day
They don't interchange, Amazon has them.
Don’t buy from amazon it’s a bad ideal ifixit has apple parts
please, who knows the exact dimensions of iPhone 6s battery? I know about different connectors, but what is its size? thanks
You can see the size of the iPhone batteries her:
http://billigeskærme.dk/produkt-kategori...
Du kan se størrelsen på de forskellige batterier her:
Vi sælger danmarks billigeste reservedele til smartphones og tablets
Go on ebay and they have one
John Price crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 71
crwdns2942667:0crwdne2942667:0 102,325
