6th generation Android smartphone designed by Google and manufactured by Huawei. Released October 2015.
3rd party Qi charging options for Nexus 6P
Are there opportunities to add Qi charging using third-party coil add-ons? My great disappointment is this not being included or at least an option.
Thanks, that's what I feared. Do you know if the back is removable, maybe there will be enough interest someone will fabricate a RF porous replacement and find accessible attachment points for charging... Not likely I guess. :-(
Perhaps a solution like iQi (currently available for Apple devices) will be released.
The only drawbacks of such a solution are:
1)that the charging module is attached over the phone so you should use a thin case to hide it;
2)using the phone's USB port may be problematic due to charging module cable attached to it.
I had been keeping that as a fall-back. Thanks for the insights.
I use a "stick on" module, and it works pretty well.
Sure, it only charges at 1W, on a good day, but I can trade the fast-charge capability for the convenience of wireless; I've had this installed since the first week of ownership.
You can sync almost everything, easily, using wireless (either Bluetooth or WiFi), so there's not a lot of reasons to need to connect it to a computer, physically, IMHO.
Obviously (I think), this involves a case, something to cover the Qi charging coil. There are numerous USB-C stick-on modules out there, of various qualities, definitely need to read reviews, and choose one with a flush-mount cable (to keep it protected, by the case edge).
Not internally, the case is metal so Qi charging won't work through it.
Perfectly Frank crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 3,424
