1994 toyota pickup dies when put into gear
Have a 94 toyota pickup and when you put it into gear and take off it dies like you turn the key off not sure if it's a ground wire problem or what any ideas are helpful
Do you have the same issue when it is not in gear? It only happens when you drive?
It's not likely a ground problem. Probably a sensor. The only time I have had trouble with my truck not running it has been a sensor. Check all connections, unplug and plug back in. You'll probably fix your problem.
You should also check to see it it's getting fuel when you have this problem. Could be a weak fuel pump.
Jeremy Hedges crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 388
