Model M7886 / 450 MHz or 500 MHz PowerPC 7400/7410 (G4) Processor
My Cube can not enter the OS.
The Cube has some parts drop down( sheetmetal, screw ring and screw) when I install the AirPort Card last week.
It just hold the power on in a few seconds to off and restart continuously, it can not enter the OS platform.
You can see the parts' picture at this website.
http://mac.hk/appletalk/download/file.ph...
Thank regards
I would open it up, and look for any more loose parts, that may be shorting something out, and causing the cube to restart. If this doesn't work, then there is a problem with the power brick, or motherboard/cpu.
Also, try removing the airport card you installed.
Try Flashing the Image...
Chris crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,067
