Repair guides and support for desktop computers produced by Asus including towers and all-in-one display PCs.
no signal from computer to moniter
Their is no signal from my Asus essentio to the monitor . The monitor is working fine as I have cctv cameras attach to monitor and it is displaying them fine, I have also checked cables which are all fine. This has lead me to believe that this could be the graphics card . I have taken a look inside the computer and I can t see the normal set up with a removable graphics card attached to the vga port so I am now wondering if the whole motherboard needs replacing. Thanks
haguehags ,
Hope This answer will hep you to get idea to fix you PC
this isnt hel[ full
Greetings,
Check the monitor for which type of input signal it is currently set for.
- there should be a choice within the set-up options for Dvi, HDMI, Display port or whichever cable type the Pc is connected to the monitor with.
- insure that the cctv cameras are not set as the default source.
Hope this helps in attaining a signal.
asus pentium3 power ok ram clean ok showing signal ditected
haguehags crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 4,500
