water is running back into reservoir
hunter, make sure that your needle valve is not occluded. check on here to make sure that the needle as well as the lines are good.
My Keurig Elite When you turn on power button it makes a noise but nothing happens(it says Not ready but does not make coffee then cuts oft) does not pump water.
Remove bottom plate.you will see water pump,sometimes when you hit the pump with a screwdriver handle like a tap it will free the pump
There are 2 solenoid in the machine,one of them is not operating. Apply 12v to test the solenoid ,replace the one not operating
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 4,873
what have you checked? What have you tried?
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
