The first generation Nvidia Shield Tablet released in July 2014. This device is often used for gaming, and has Wi-Fi and LTE capabilities.
Why is my battery dying so quickly?
My battery doesn't hold a charge for my Shield Tablet, is this a common problem, and do I need a whole new battery to fix it?
how old is the tablet and how much use does it get
crwdns2933315:06crwdne2933315:0
You could be experiencing this problem due to a range of factors. One option is that your battery could be going bad and will need to be replaced, however that is a last resort fix and should be avoided until you run out of other options. I would first try some other possible noninvasive fixes. Try turning down your screen brightness and turning off your Bluetooth when not in use. Avoid running your device down to the last percentages of battery as this reduces the life of the battery dramatically over time. If you enjoy using your tablet while it is on the charger this can contribute to a shorter battery life for the devices current charge.
The charger could also be the issue. If you are not using the cable that came with the device as it's primary charging cable this could be a contributing factor. If you are using a third party USB cable that plugs directly into an outlet the improper voltage/amperage can harm the battery permanently. Make sure you are using the correct charger for your devices. Depending on the device overnight charging can be harmful as well.
There are many factors that contribute to a rapidly dying battery, most of which are preventable by changing a few habits surrounding the usage of your tablet.
you need to find out what batery is in it.
the shields from june 2014 to june 2015 have a bad batery.
check out google for the information how to find it
You should update your shield tablet to 3.1.1 (android 5.1.1).
After that go to settings -> about tablet -> status.
Now it displays your battery type. If there it says Y01 you're in for an replacment.
Follow that directive here:
http://tabletrecall.expertproductinquiry...
I also have one with bad battery and got an replacement.
What you are describing is a common problem among all greatly used batteries. Yes you do need a new battery
The cable of the charger is damaged.
Has anyone had the chance to replace the Mico charging port on the Nvidia shield having problems with the charging AND IT'S NOT THE BATTERY been there n done that. So if someone has change the charging port let me know thanks
Molly Bauer crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 12,196
