Repair guides and support for computer monitors produced by Samsung.
Monitor turns black after a few minutes
This Samsung Syncmaster 940NW monitor works fine except for the fact that it turns black after a few minutes. A few minutes means: 5, 10, 15, 20 or whatever minutes it likes to stay on. What could be the cause for this blackout?
did you do a backlight test? is there any video?
Any problem associated with a time to react must have a heat component. Any component can do that, so starting with the easiest to test is the way to go.
Black screen - backlight test. then capacitors, then voltage checks, then it gets difficult and becomes a board swap process.
John Van Dael check your power supply for bad capacitors. It sounds like you are losing either your backlight or total power.
THX Oldturkey. I will check this out as soon as I have time.
Checked electronics. No bad capacitors.
If the capacitors are the course of the problem, would the screen go back to normal within 5-10 minutes. Or is it more likely the screen stays black.
I am using this monitor (Samsung Sync Master 940NW) for more than one year. Since a month the screen stays black after switching on my pc. I am using two monitors, so I am able to work, but some frames start at the SyncMaster and so I am not able to continue. The issue takes 5-10 minutes.
The manual can be found here:
https://www.samsung.com/nl/support/model...
This manual suggests a relation with the power setting:
PowerSaver
This monitor has a built-in power management system called PowerSaver. This system saves energy
by switching your monitor into a low-power mode when it has not been used for a certain amount of
time. The monitor automatically returns to normal operation when you press a key on the keyboard. For
energy conservation, turn your monitor OFF when it is not needed, or when leaving it unattended for
long periods. The PowerSaver system operates with a VESA DPMS compliant video card installed in
your computer. Use a software utility installed on your computer to set up this feature.
State Normal Operation Power saving mode
Power off
(Power button OFF)
EPA/ENERGY 2000
Power Indicator Blue Blue Blinking Black
Power Consumption Less than 20 W Less than 1 W Less than 1 W
This monitor is EPA ENERGY STAR® compliant and ENERGY2000
compliant when used with a computer equipped with VESA DPMS
functionality.
As an ENERGY STAR® Partner, SAMSUNG has determined that this
product meets the ENERGY STAR® guidelines for energy efficiency.
I changed some settings without any result.
My temporally work around was changing to one monitor and extend it later on when the SyncMaster is working normally.
monitör 5-10 dakika beklemeden sonra çalışıyor olsaydı kondansatörler nedeniyle bu problemi yaşamış olurdun. Ama senin problemin açıldıktan 5-10 dakika sonra kapanması. bu ekran kartında veya panele bağlı olan kartta problem olduğunu gösterir. bu da ölçüm yapılmadan bilinemez.
Translation Turkish - English
If the monitor was working after 5-10 minutes of waiting, you would have had this problem due to the capacitors. But your problem is that it turns off 5-10 minutes after it is turned on. this indicates a problem with the video card or the card connected to the panel. this cannot be known without measurement.
Hello Bomcli,
That is exact what is happening. You suggest the problem is the capacitor(s). But which one. I assume within the power supply. Do you have more information. I would be pleased
John Van Dael crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,178
