Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
crwdns2934055:0crwdne2934055:0
Touch Screen Not working
So I just went ahead and replaced my mainframe since it was damaged.
I removed the screen without any issues, removed the logic board, replaced everything back. But for some reason, my touch screen is now not working. You can see everything fine on the screen. The screen works, but touchscreen is not. I tried the 1 minute power-hold technique almost 3-4 times. But nothing happens. Any reason why this would happen?
The exact same thing has happen to me. I replace good working phone with a new bezel and now the touch isn't working. How did you resolve this?
Check the back panel of the screen, sometimes just reheat that part solve the problem.
If this don´t work check for any damage in the components or broken solder.
I have checked all my components and they are undamaged. Is the back part you referring to, the copper foil?
i refer to the flex ribbon in the back if the screen yes, the touch screen conector is on the right side of it. If there is no damage in there you must replace the hole lcd
It appears that I have torn the touch sensor flex cable completely from opening the phone.
Is there any way to replace just the sensor without changing the entire lcd. I found the replacement part here: http://g02.a.alicdn.com/kf/HTB1_YdWKXXXX...
its possibly but required a high skill whit the heat gun.
crwdns2942667:0crwdne2942667:0 2,206
