The tenth generation Ford F-Series is a line of pickup trucks that was produced by Ford Motor Company, it was sold from the 1997 to the 2004 model years.
How to replace rear axle bearkings
how to replace rear axle bearkings
It s a long process so Ill let someone else show you
https://www.youtube.com/watch?v=BKcK6WqS...
https://www.youtube.com/watch?v=zjZmG4qw...
https://www.youtube.com/watch?v=3lUykh8H...
https://www.youtube.com/watch?v=7Pds5Knn...
https://www.youtube.com/watch?v=BTNNjpkE...
https://www.youtube.com/watch?v=Kz_pWqXX...
https://www.youtube.com/watch?v=zAwq3Fcn...
Lot of video but very detailed
its in parts 1-7
carmieandjason see if this will help you out:"
Removal (With Rear Drum Brakes)
1. On vehicles with air suspension, turn air suspension switch to OFF position. On all vehicles, raise and
support vehicle. Remove wheel assemblies. Remove differential housing cover, and drain lubricant. Remove brake drum.
2. Remove and discard differential pinion shaft lock bolt. Remove pinion shaft. See Fig. 2 . Push axle shaft inward and remove "C" locks. Remove axle shaft, being careful not to cut axle seal. Using a Axle Wheel Bearing Puller (T83T-1225-A) and Slide Hammer (T50T-100-A), remove bearing and oil seal as a unit.
Update (10/02/2015)
Here is a great guide.
carmieandjason crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,161
