The USB is connected is turned off
El telefono apagado carga la bateria con el conector de carga.
El telefono prende normal sin el USB pero cuando esta prendido y se conecta el USB se apaga
Ya se cambio el Cable, El puerto De Carga, La bateria.
The phone off charge the battery with the charging connector. The phone turns on without the USB standard but when he is on and the USB is connected is turned off And will change the cable, the charging port, battery.
