hub keeps getting loose
The hub of my back wheel Coster brake keeps getting loose when I ride and the wheel wobbles and so I re tight it and it does it again and again
If you mean the Nut is getting Loose then it could be that the Thread does not fit anymore, this you can test by using the Nut from the other Side on the Problem Side. If The Problem switches from the one to the other Side you should use Locktide.
crwdns2942667:0crwdne2942667:0 136
