crwdns2934055:0crwdne2934055:0
still flickering screen after data cable change
I replaced the data cable, it helped a bit but not completely, if i tap the top edge it still flickers depending on the angle of the screen... I also dj in clubs with bass and vibarations and sometimes it makes it flicker, anything else could cause it?
there's no flickering taping it on external screen
how is it solved ? ???
This laptop used different LCDs. Some used flourescent backlit LCDs, some used LED backlit LCDs. You need to open your computer and tell me which yours used so I can help you find a panel. Can you provide us with the number on the back of your panel?
It will be something like
LP171WE2(TL)(A2)
Go!
If you want to fix the computer, replace LCD itself. In my opinion this is a lost cause because the GPU on this will die months after you replace the LCD and new LCDs for this machine stopped being available about seven years ago. It will be a pain in the @%^ to find a working LCD and when you finally do you must be prepared for the discouraging feeling that occurs when you fix A and then a month later B acts up and makes your work on A worthless.
That's because it's the screen. The idea that the cable is bad is an internet myth based on wishful thinking that the problem can be solved for five dollars, which is rarely, if ever, true.
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 73
