Repair guides and support for cars and other vehicles produced by the Chrysler division of the Fiat Chrysler Automobiles US LLC.
cruise control quit working
nothing works with the cruise, the "cruise on " indicator light doesn't come on when I push the cruise on/off button on steering wheel
2012 town and country
crwdns2944067:010crwdne2944067:0
2006 dodge grand caravan. ABS and Break lights come on. I have never used cruise control. Bought it used 3 yes ago. When I turn off the engine the servo unit keeps running. WTD?
I read all the comments and I'll be damned if hitting the steering wheel got mine working aswell!!! Woot! I use it ALL THE TIME! Was lost with out it! 2011 Chrysler Town and Country!
I can’t believe it…it works! Two hard pounds to the back of the steering wheel near the cruise control switches BOOM ? Thank you to those that answered and commented!
It also worked for me. How long? But it worked. Thank you
Hello 2014 grand caravan with same issue , a little hit in the steering wheel and works! Thank you
crwdns2934275:05crwdne2934275:0
crwdns2933315:011crwdne2933315:0
john b , Defective speed sensor, bad cruise switch/wire connection, bad brake light switch,etc can cause cruise not to work properly. If engine light on, record the code to help diagnose the issue. You may have to find a good Tech. to diagnose and estimate repair. Good luck.
crwdns2944067:045crwdne2944067:0:
Smacking the dash and steering wheel worked for me as well
Son of a ##&&%, my cruise wasnt working, so i just smacked dash and steering wheel. Sure as $@$* it started working again lol
Smacking the dash and wheel worked for us too! Thanks!
Holy s@$&! Smacking the steering wheel worked for me too! I had to try it after reading the comments
Holy crap!! Dash & wheel smack on my 2016 just worked for me, too!!!!! I don’t know if I love this or am really upset by it...
crwdns2934275:040crwdne2934275:0
I have a 2012 Dodge Charger. The cruise control on off button sticks or doesn't make contact to turn on. I have found that if you whack the steering wheel hard on the back side of the module a few times it will most likely start working again. I know this isn't ideal and the module needs replaced but it does work until you can replace it.
crwdns2889612:0crwdne2889612:0 16
crwdns2944067:028crwdne2944067:0:
We are on a long road trip to florida and the cruise quit. Started reading every post about it and found this one. Smacked the side of the steering wheel and I’ll be hanged if it dodnt turn back on.
This just happened to me and it worked! Seriously!! Jeremy... did you do anything long term?
It worked for me too!
Unbelievable I'm driving down the freeway hit the back of my steering wheel and it works
10/10. Worked in Canada too. Thanks Barry. You’re a genius.
crwdns2934275:023crwdne2934275:0
I have a 2014 T&C. I made a fist and smacked the side of the steering wheel (where the cruise control cluster of buttons is mounted) firmly 2x. I did not hit the buttons themselves or their housing directly. Result? Cruise icon lights up in the dash and cruise function works!
Omg! It totally works!
My wife has a 2012 T & C and turning ON the cruise was intermittent at best. I am an electronics tech, and decided to try spraying some electrical contact cleaner in the air gap around the ON/OFF switch in the steering wheel controls before going to the next level and replacing the switch. After applying the contact cleaner, I then dried it at the same point with a can of compressed air (computer keyboard cleaner). No more issues, cruise switch works every time now.
crwdns2944067:08crwdne2944067:0:
Omg it worked for me too. 2012 grand caravan crew. Up here in Canada.
I mean hitting the steering column and steering wheel.
I have a 2012 crysler 200 cruise works sometimes and sometimes it doesn't what can I do
So I thought all the comments above were a joke but.....it actually worked
2015 Town & Country. No cruise, read the smack solution. Bam bam, works! Thanks!
Is the Check Engine light on? Alot of newer cars will disable the cruise control when the check engine light is on .
That's crazy!!! I just tried this and it worked!!! I've been without cruise control for a few weeks. Amazing!!!
I removed the switch, opened it and cleaned the tiny connectors that were corroded where they touch the female connector from the wiring. The cruise control worked ever since…
I just worked on replacing brakes then my cruise control would not work. Thought it was a speed sensor but I have no warning lights on. Read these comments and I hit the steering wheel to see if that would fix it. Like magic it works now.
Holy Crap!! I googled this…My 2014 T&C Chrysler, cruise overnight Stopped working. Saw this, tried it, And It did work 🤗
Thank you!
Just smacked it after driving four hours . WORKED WTF!!
SMACK IT!
So my brake light went out, my ignition won’t catch til the second time then does immediately, cruise quit,it felt stuck ,not coming back up, smacked it and it felt normal again,orange engine light has been on, had it coded-no issues. One week before this all started the air intake sensor went down. Other than that she’s been running great..still no cruise control
I have a 2012 Dodge Durango RT. Cruise control stopped working. So glad I found this thread. Banged on the side of the steering wheel near the cruise control buttons. Boom. Like magic, cruise control works like it should! What a fix.
john b crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 73
crwdns2936753:030crwdne2936753:0 340
crwdns2942667:0crwdne2942667:0 59,143
