Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
Why is my digitizer freaking out?
Hello! I recently purchased an iPad for repair purposes. Unbeknownst to me, it was an EMC 2560 model. I'm still waiting for a response from the seller but in the meantime, I stuck a 2415 white digitizer I had lying around on it. Now it's freaking out. As I'm writing this I am in a constant battle trying to type legibly. It seems to Szvxbzv. There. You. Egg go. Right then it malfunctioned. It randomly types keys, and registers random signals. I'm not sure what the problem is, is it my digitizer or the fact that I put a 2415 on a 2560 logic board? Or neither? Thanks!
All iPad 2 digitisers are the same, EMC 2560 was just a revision of the EMC 2415.
So that wouldn't make it do that.
There are several possibilities that could cause this:
Faulty replacement part,
Dirty digitiser connector on logic board,
Digitiser not inserted correctly,
Digitiser cable not seated correctly down the side of the LCD and has been trapped under the glass, this one is quite common and damages the cable,
Or worst case scenario would be logic board damage.
You Just crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 206
