In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
check engine light is on most of the time
the first time it went on i brought it to toyota and they said it had something to do with the gas tank cap: $98, the 2nd, 3rd, and 4th times, it started when i added gas, but it went out after 2 or 3 gas refills. now it's been on for a few months. so what's up?
Have you gotten it rescanned? What error code did you get?
The reference to the problem occurring shortly after refueling strongly indicates a problem with the gas cap. Make sure that the gas cap is clean, that filler has no debris, and that the O-ring is in good shape. When you refuel,, make sure to always turn cap until it clicks a couple of times (depends on the cap). If cap is not secured properly, you will get a check engine light every time. There are other possibilities, but this is the one that plagued my wife's car until I replaced the gas cap and reminded her to always fully install the cap. A new cap should be less than $20 if needed, so it's a painless fix and the most common cause. I get the same outcome when I am careless when refueling my Camry.
Mine reads error codes p0141 and p1349
Take it to an AutoZone and get a free computer read out, compare that to what your dealership is saying and let us know your results.
Or take it to O'Reilly formerly known as Shucks. Free reading as long as they have the reader
steve crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,841
