Repair information on products used in health and personal care. Fixes tend to be simple and require only common tools.
Despite new batteries, my Bathroom Scales still does not work
Why does it not register weights?
I have fitted new batteries but the scales does not reregister to zero and show letters in place of weights?
Can l fix?
My Starfrit Balance bathroom scale also stopped working and replacing the battery didn’t solve the problem. I turned it over, took out the screws holding the casing on and examined the feet that contacted the scale. Each little footpad had a metal disk that was supposed to connect with a corresponding metal sensor that was wired to the scale.
Each connection point was slightly oxidized, not a surprise considering that the scale lives in a humid environment. I cleaned both the foot side and the metal contact point on the scale with fine sandpaper to remove any oxidation. After putting everything back together and replacing the battery, it now works.
I did this to mine and it only works when the battery is removed and then put back into the machine, Only works one tim then need to reinstall the battery???
Mine is the exact same I have to remove battery then put it back in to use it and it only works the one time then wont come back on. Have you found a fix for this?
Leave it without battery for more than 5 minutes some of them have this way as a reset , mine worked now but maybe tmrrw it will stop again
Clive crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 167
crwdns2942667:0crwdne2942667:0 4,279
