The Acer Aspire 8920 is a series of notebook computers released in 2008 by Acer, Inc. Acer is an electronics corporation based in New Taipei City, Taiwan. The 8920 model was released as part of the Gemstone series and was the first 18.4-inch screen notebook produced by Acer.
laptop resetting during install
can anyone help my laptop keeps switching itself off and restarting during restore even if i use a stand alone windows not restore i have even tried from usb stick windows 7 BUT if iinstall linux or hackintosh its fine installs ok just i even have replaced the hard drive twice does it on windows any ideas
i think you forgot boot disk uttulities run over it
Hello richardapayne
Sounds like a driver, a memory problem (not to sure why other OS's work though)
Does it restart at the same spot during the installation? If yes what is the installation doing at this time?
I would try running memtest86 for at lease 5 passes (I leave it run all night.)
http://www.memtest86.com/
When in Lunix run psensor to check your CPU temps. When installing Windows the CPU can max out and if the CPU gets to hot the computer will reset or turn off.
http://wpitchoune.net/blog/psensor/
My aspire 8920g restarting with power is on.
In the mode safe works ok.
I had the same problem and after a bit of research I found out that disabling the two cpu cores in the device manager in safe mode solves the problem. Here's the link to the source: How to fix a notebook that freezes when plugged to AC power?
that common in 2008 models. try to update bios. https://www.acer.com/ac/es/ES/content/su...
The answer to this Reboot problem is the Capacitor located right under the CPU. Setting the CPU to use only a single core cpnfirms this is correct. There is a repair video on youtube that shows how to do this. The Original capacitor (Single Unit) is peeled off the board and replaced with 4 x 330uf - 2.5v Tantalum capacitors in its place.
It takes patience and care to complete, but is NOT too hard for most enthusiasts.
Whats needed: 2R5TPE330M9 330E 330 330UF 2.5V D SMD tantalum capacitors
i have the same problem while trying to reinstall windows vista home premium because they got corrupted during a windows 10 installation and trying to boot results to a restart
richardapayne crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 2,234
