picture when playing EU movie "runs"
The players plays perfect NAmerica movies, after hacking code plays Eu movie: voice is perfect, picture is clear but the lines jump in the constant sequence as if there was adjustment of the speed needed??
Single pictures are dropping down from the sky like rain..
dvp 642/37 sept 2004 serial KN010439623307
Thank you for advice on how to diagnose/fix the problem.
My other 642 from 2006 plays anything fine.
Adam
PAL vs NTSC difference is the first that comes to my mind. Secondly it could be due to the DVD's region code. It is set for Region 1 only, but that most likely would not give you the running image. How do you connect the DVD player to your TV? what TV are you using?
