Why is my bonneville leaking from the driver side?
Bonneville is leaking what I think is power steering or brake fluid. My wheel gets tough to turn corners.
You've probably broke a line from the steering rack to the power steering pump or the seal has gone in the pump . Are you hearing a whine, if so get this fixed right away before you burn out the pump. A pump is a lot more expensive than a replacement line. DON'T let your pump run out of fluid.
if its brake fluid you'll be out of brakes soon so be careful
I wouldn't be driving it until its fixed either way
If your finding it hard to steer than you probably need a new pump already
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 223
