The Nokia E63 is a quad-band GSM that includes UMTS support. Is is released in 2008.
crwdns2934591:014crwdne2934591:0 crwdns2934593:0crwdne2934593:0
My phone is switched off due to falling in sea water
my nokia e63 got switched off because sea water went into it when we went for a sea what will i do
crwdns2933315:07crwdne2933315:0
Act fast
  • Remove sim card and battery
  • Rinse well under the tap, use running water
  • put it in a hot, dry place. I have used my oven, set it at 50 Celcius, and leave the door open. Leave it there for several hours.
If you are lucky this can save your phone. If not you need to open it up and clean it up. And even then it might not work.
crwdns2942205:01crwdne2942205:0:
If this solved your problem, please mark the answer. =)
I have done almost exactly what rousp said (the difference is I don't use oven, I used the sun heat because I'm in Jakarta,Indonesia).
And my Nokia 7610 work fine again.
You lucky ... =P
I'm in Norway. Middle of summer, 12 degrees celcius and raining....
I am. :D
In Jakarta on whatever season, it's about 33 degrees of celcius.
Sure it's HOT... :D
Hey does this really help for Nokia E63...??
It should in theory work for all the equipment. What one needs to do is to ensure the equipment does not get turned on. I try to remove the battery as well, open the case and use isopropyl alcohol (Isopropyl alcohol is used as a water-drying agent) to clean the PCB due to corrosion issues. If you follow the numerous answers on ifixit.com in regards to immersion you will find plenty of free expert advise about that subject. Good luck
If the phone was on when it got wet I would bet that it no longer works. Drying it out might work for a time but the 'high conducting' salt water was bound to short out and create latent damage in the semiconductors which could take weeks to rear its head. It would also corrode the protective film on the circuit board allowing the copper traces to oxidize and short.
Also, just drying out the unit without an alcohol scrub will let the water evaporate and leave the salt behind.
Nokia makes durable phones but this little fella just might have bought the farm. :(
i have a nokiae63 it has problem of mic please give solution
Nitin, it works so much better if you as\k your own question. Click on the link on the right side of this screen "Ask a question" and give as much information as possible. Such as, what happened to the phone, what have you done to try to fix it etc...Good Luck
i have drop my Nokia E63 in detergent water an i immdetly remove it from the water an i hav open thing to dry up in the hit ..but it desnt work agin in the morning time i left in the sun for dry even this does not work an i took it to mobile center to check out ...but they say the has been short an cant do anting ....pls help me out to solve this problem ...as pholne laying ded on the table.....
My Nokia BL 5CB dropped in water
subhash crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 3,296
