My MacBook Pro Wont Turn ON
My MacBook Pro wont turn on, i was working with it at night and i put it to sleep, i woke up the following morning to turn it on .... nothing happened i tried all the diagnosis but none of it worked, resetting the PRAM and the other ones but its not working .. can some one help me please .
Thank you
Update
hello mayer and every one that read my problem ... i tried what you suggested but it didn't work i even tried leaving it for a day without the battery and the charger in it . i read something from the apple forums and guys there were said something like it was caused by the NVidia card .. what do you think ?
thanks
Update
guy i need help .. they apple shop here said my logic board needs to be replaced and they said its gonna cost me $ 1,465.60 to do the replacement and thus just like buying a brand new mac ..please somebody help me out ..
crwdns2933315:06crwdne2933315:0
Remove the battery and unplug the AC adapter. Hold the start button for 10 seconds. Replace the AC adapter and try to start without the battery. Please tell us if it does anything, makes any sounds or any lights, thanks.
Failed GPU Apple Program or Other Repair
Here's a link to the Nvidia issue. You symptoms reallt didn't bring that to mind but it's worth a shot. Use the number listed in the "Contact Center" answer. If they turn you down come back and we'll work on it some more.
try to power it on without the battery - does it react in any way ?
i would try the opposite of that too - try to power on the computer without the magsafe connector.
when you press the button on the battery - are the lights showing anything?
as mayer asked before - any lights, any sound - anything ???
hello guys i think you have to send your Mac to the apple care shop because this is not some regular fix.
You might need to replace the NVidia card which is also built on board and this should also mean that its going to be the whole mother board. Thus gonna be quite expensive , so its better to send it to any closest Apple Care shop to get the part replaced rather than trying to amend your board in some way which might not help in the long run ...i'll be sending mine to the Apple shop here in Ghana so i'll keep any news up and posted thanks for reading again guys i really appreciate it .
Thanks for your help check out my MacBook fixing blog
http://tinyurl.com/nchvrsx
1.unplug the AC adapter
2.turn the mbp on
3.leave it on, until it turns off because of no battery
4.plug the AC adapter
5.wait until magsafe light is green (full charge)
6.turn it on
it work for me, but in the next restart it failed again, but at least you have the opportunity to do something.
Aww Deng i didn't see this earlier i sent it to the apple care shop today...so guess i'll be hearing from them quite soon . thasnks guys
Great somehow worked, my MacBook turns on and works check out my blog about Apple MacBook pros and Apple iPhones, many thanks
David
Am so Sorry to hear that you cant play Minecraft on your computer but there is always a way to fix this problem there are lots of methods out there but i think you need to use youtube and search for a good one …hope my suggestion helps ..
"If you want your MacBook to wake from sleep when you open the lid of the machine, all you need to do is
launch the Terminal and type the following command
pmset -g profiles
see if
lidwake 1
if 0
it is disable"
sudo pmset lidwake 1
makes it enable.
I was having problems with my Macbook not waking after 10 min of sleep. Looked everywhere and found this on the web and applied it to my mac.
Now works when I open it form sleep. ONE happy lady. wanted to share
maybe it will help others with 'won't wake after sleep mac's.
@Szabolcs Nemeth i managed to fix the issue using a good tutorial i forund on you tube had to heat up the nVidia Graphics card for some time i used a heat gun so you should be careful when doing this. It may damage some tiny Conductors on the board. i sold the it though so it's been a while now.
daniel dizzy crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 10,992
