What does the f22 error code mean
I ran a load last night and woke up to a F22 error code flashing. I am going to re-start the load. Is this something that will need follow-up?
Diana Timmons, the F22 is a door lock failure. It will only occur after the control has tried to lock the door 6 times. The most likely cause of this problem is the door lock assembly is bad. You can try to hold the door shut a little tighter. If the door is not shut all the way or is crooked then the door might not latch. The door latch assembly is the most likely part to cause this problem and I would recommend replacing it. Get the service manual for your washer from the bottom of this page. The door lock is part number 8183270
Hey Diana, the f22 error for this washing machine usually occurs when the door isn't properly shut. Please make sure that the door is shut all the way. Also, if the problem persists then I'd recommend that you replace the door. You can get it replaced through warranty or manually.
-Let me know if this helps
There's no adjustment on these doors and I shut it properly. My problem is that it won't unlock, it locks fine.
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 247
crwdns2942667:0crwdne2942667:0 30,278
crwdns2944067:07crwdne2944067:0
Hi Diana, I know this is a very long time ago, but could you let us know if replacing door lock, part number 8183270, as @oldturkey suggested, fixed it?
crwdns2934271:0crwdnd2934271:0 Daniel Mare crwdne2934271:0
I have this same issue, I ordered and replaced the Door Latch still getting the Error Code F22
crwdns2934271:0crwdnd2934271:0 Tom Harrison crwdne2934271:0
@motleytom a year later, did you end up fixing it? If so, what did you need to do?
Is this the same on hotpoint condenser dryer it starts for a bit then F22 appears
crwdns2934271:0crwdnd2934271:0 Laura Evans crwdne2934271:0
Hi @Laura Evans,
What is the model number of the dryer.
Looking online most Hotpoint dryer error codes only go up as far as F17.
Is the error code being displayed as "F22" in a display window or is it being displayed as LED lights that have to be interpreted as to the code?
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
crwdns2934275:02crwdne2934275:0
