Will not charge, the charger is working
the charging port on my 10" irulu tablet appears to be broken, is there any fix available???
First clean the charging port with a firm bristle brush (toothbrush). Then inspect port and make sure the tongue isn't bent. Try to charge. If it still doesn't charge. Use the disassemble guide. Only go far enough to use a volt meter to see where the problem lies. 95% of the time it is bent prongs (tongue) of the charging port; created from improper mounting of the charging cord. Sometimes it is simply dirty, and unfortunately sometimes the port will come completely separated from the board. This is from improperly inserting the cord and then trying to force it in, instead of reinserting the charging cord properly. Last but not least, from forcing the wrong charging cord into the charging port. Good luck
Are there any replacement ports that can be attached?
yes replace it if you dont have one try to rehot the one you have
A solution that worked for me was to disassemble and unplug the battery. Held power button down for 20-30 secs to fully discharge motherboard. Re-connected battery and all started working again.
Do you have a Youtube Video of how you was able to accomplish this Task, to get it back in Operational Functionality Working Status.
You can send the YouTube Video to my E-Mail Address below or Just send me a Link to your Video.
E-Mail Addresses Below:
1: jbitconsultantcomputersystemsandnetworksservices@outlook.com
2: jbitconsultantservices@gmail.com
drookjames crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,241
