I have exactly the same circumstances, dropped two feet and power button stuck in.... luckily Apple has in built workarounds for this, the iPad will always power up if the battery goes, you can do a reset by holding the home button but it will only go blank then show the Apple logo in repetition, but you attach your lightning cable to charge and your iPad will turn on, also turn on your on screen home button and add functions such as screenshot, lock screen etc, and your iPad will function as normal, in fact I find it better. Mines has carried on for several months now no problems at all, bit concerned when I first did a reset with the home button but attaching the charger brought it on. Now I am to attempt to free the power button, I am not sure if I should as all is good but I experiment so first I gently filed round the power button to remove any sharp edges. Now I am going to heat up a needle, bore a tiny hole in the centre of the button, and use a tiny screw (from an old dismantlement iPhone) and hopefully screw in to pull out. Obviously not a hammer and grinder job. I don't advise opening your iPad, they are not really designed to be opened without using new parts, many have ruined their iPad trying as there is a cable which breaks if you pull the screen up too far so don't try this option... even Apple suggests replacement over repair. But if you follow the above workarounds, you should have no problem. Twice I lost sound but the reset fixed this.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
9
crwdns2944067:07crwdne2944067:0
Mine is the volume button can you help me please
crwdns2934271:0crwdnd2934271:0 supermum6789 crwdne2934271:0
my power button is not stuck but it doesn't work. Please someone help me. :(
crwdns2934271:0crwdnd2934271:0 hotdogman 896 crwdne2934271:0
Supermum and Hotdog…. Follow the instructions I gave above, Supermum the screen home button has volume control….. but hotdog one problem is if you turned the iPad off yourself, then it will not turn on when you plug it in unless you keep pressing the power button while it is plugged in and see if that helps. Apple tablets are just not made to be opened, usually the screen breaks or some ribbon gets broken so you end up fixing more and more. Even independent workshops will tell you this, however if you have a spare week then you could try extremely carefully to try to take the screen out and the power button should be able to be able to be replaced, put together with tiny blobs of superglue on each corner… good luck
crwdns2934271:0crwdnd2934271:0 Martin Irving crwdne2934271:0
my iPad middle Button is stuck inside the iPad how do I fix this?
crwdns2934271:0crwdnd2934271:0 hello crwdne2934271:0
My I pad has the power button stuck in the place for it but it will not come back up can some one plz help me
crwdns2934271:0crwdnd2934271:0 Faith Collum crwdne2934271:0
crwdns2934275:02crwdne2934275:0
