Why my calculator is not charging?
When I plugged in the charger, it shows greenlight but still low battery even though I charge it overnight
Try using the reset button on the back. That fixed it for me!
It worked for me as well!
reset button on the back meaning?
Using the reset button on the back worked for me too.
Where is the reset button?
It doesn't work at all...
I read on another site that if you unscrew the battery compartment, unwrinkle the cords, it will charge better. I didn't think that would work, but strangely enough, it is charging and actually working. Hope this helps.
It worked! thank you :)
Reset your calculator: If you turn to the back of your calculator in the mid-left you will see a small button that says reset.
If this method doesn't work for you then you might have some other problem.
If your graphing calculator isn't charging and it doesn't take 4 AAA batteries then it works on a block battery that you have to unscrew the 2 screws and unplug it for 10 seconds, plug it back in and tighten the 2 screws and charge it and it will function normally.
Your calculator battery may be reduced in lifespan and it could also be your charging port. You can buy charging ports for TIs and other brand calculator online.
crwdns2942667:0crwdne2942667:0 72,203
crwdns2944067:09crwdne2944067:0
crwdns2934271:0crwdnd2934271:0 dirkathena crwdne2934271:0
how do you open the battery compartment though? mine wont open
crwdns2934271:0crwdnd2934271:0 Sarah Durbin crwdne2934271:0
Sarah Durbin you checked this guide?
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
This worked for one of my students. Thanks for the suggestion!
crwdns2934271:0crwdnd2934271:0 Kathy Hansen crwdne2934271:0
but what if you have the one that is color and doesn't run on batteries
crwdns2934271:0crwdnd2934271:0 Ian Greenwood crwdne2934271:0
crwdns2934275:04crwdne2934275:0
