The Jeep Cherokee (XJ) is a compact SUV that was manufactured and marketed by Jeep from 1997 to 2001. Sharing the name of the original full-size SJ model, but without a traditional body-on-frame chassis, the XJ instead featured a light-weight unibody design.
horn repair and airbag light is on
My airbag light is on and my horn does not work, they both failed at the same time,
Sounds like you need to replace the clock spring Its the wire harness that keeps your wires conected as you turn the steering wheel.
https://www.youtube.com/watch?v=VxYHC6oX...
This is a brief tutorial on replacing one. Hope this helps
check the airbag clock spring...
It's the clock spring I figured it out after i reset my dash lights three times and it illuminating my airbag light..
argyjpolsinelli crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 7,949
