crwdns2934055:0crwdne2934055:0
What are my options for a 7200 RPM HD?
Hello all. I have a powerbook with the factory 100gb 5400rpm drive installed. Although i have recently did a fresh install of 10.5.6 and updated.
I am getting a little worried about space and speed issues as i am using this machine to trigger samples live and other smaller audio projects. I would like to either install a larger faster drive or a larger drive just to try and keep the amount of variables of something going wrong down at least by one.
I have heard that a drive starts to 'degrade in performance' sometimes when as little as 50% of the drive has been written to and although i am not actually writing to the disk in a live situation the disk is still spinning...
I have written the longest post known to man :. Anyway, thoughts?
Thanks in advance!
So what is the actual question?
I do in fact have a powerbook so no SATA for me :( only (p)ATA aka ide.... anyway, i found bigger drives for use just no 7200 options... bummersville. Please let me know if you have any idea where i can find a 7200rpm PATA drive and thank you!
It is true that performance decreases as you fill the drive. This is due mostly to the fact that information on the outside of the platters spins at a faster linear velocity than that at the inside and can thus be read more quickly.
As far as replacement options go, you can currently get a 500GB 7200 RPM drive but only if your machine is SATA. No 7200 RPM drives exist for PATA unfortunately.
Hitachi makes a 100GB 7200 PATA drive.
http://micropartsusa.com/index.php?targe...
Some of the measurements on that one look slightly off, it may not fit.
check e-bay. i bought an Hitachi 80 gb, 7200 rpm recently for $80 which included shipping. they also offer larger (100 gb?-120gb?) for slightly more. works just fine
@ rab777 - it's working in my powerbook as we speak.
Okay, good to know, you can't always be sure about these things, 1 millimeter off and it doesn't fit in the case.
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 1,981
