The Fujitsu Lifebook UH572 Ultrabook was released in August 2012 as one of the first Fujitsu Ultrabook computers.
Lost all power. No lights on laptop when plugged in,
It is not the charger for definite. What can I try?
Hi,
Had the same problem with my AMILO XI 3650. Seems to be a very common issue as i found in the net.
Its the the receptacle for the charger plug that gives a bad or no contact. Since i could not open the laptop (some hidden screws ??), i just removed only the cover that gives access to the fan and DRAM slots.
If you remove the fan (very easy - only 2 screws) you can see this receptacle behind.
The problem is the center connector (i.e. + pole) which is neither welded or soldered to its base platen but only pressed in. So, after - in my case - some years of use this connection gets loose due to mechanical stress ( you pull on the cable of your charger now and then) and the consequence is a bad contact.
The plastic of my charger plug literally melted because of this
bad contact with its high ohmic resistance. After a while, my laptop was completely dead - as yours.
Since you cant reach this receptacle with a solder iron by just removing the fan, i drilled a hole of about 10mm in diameter just above the receptacle and soldered this rotten connection.
Everthing is working fine since more than 6 months now !!
P.S.:
Its also a good idea to replace the plug of the charger and clean the contacts of the receptacle carefully - eventually with some sandpaper.
Hope i could help you - good luck.
Motherboard may have been short circuited. As a result, No light or No sound of turning on the System.
Watty crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 3,475
