Replacement of hard drive with larger capacity cause issues?
Hello! I need to replace the HD in my iBook G4 12" 1.2GHz 30GB HD. I'm looking at buying your IF107-069-1 (320 GB 5400 RPM Western Digital ATA Hard Drive). If I replace my HD with a larger capacity HD will I loose any functionality?
Also, is there a larger or faster RPM HD for sale for this model? The reason I ask is because I once tried to replace the HD in a G3 iMac with a non-approved HD and that iMac would no longer go to sleep.
Colleen, thank you for the prompt response!
If Colleen's answer helped you, you should accept the answer. If you're still not sure of a resolution, at least vote her post up.
I haven't had any problems with replacing these hard drives. Anything ifixit sells for your model should work just fine.
I think size is more important than speed. I stuck a 7200rpm drive in my MacBook but haven't really noticed any difference.
Just had 10.4 installed on my iBook with the 320 GB Western Digital hard drive I bought from iFixit.com. The WD works well and the computer goes to sleep as usual. Thanks for your help Colleen!
I agree with Colleen. Especially with a G4, hard drive speed is not going to be the bottleneck, as long as you are at 5400RPM or faster.
Stafford crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 3,612
